Other Parts Discussed in Thread: DS90LV011A, DS90LV012A
Hi team,
Customer is looking for LVDS TO TTL solution, could you please tell me which solution is suitable for my customer request, thanks.
Hi team,
Hi Malik,
Customer is looking for below spec,
Convert LVDS signal to TTL. your solution doesn't meet customer requirement.
Jason
What exactly is meant with "TTL"? That technology has been obsolete for decades, and nowadays is used to refer to multiple incompatible CMOS voltages. What supply voltage and signal voltage are required?
There is no 175 MHz LVDS receiver that can run with a 5 V supply. All fast receivers (like the DS90LV012A) require 3.3 V or less.
Hi Jason,
This is correct we do not have any LVDS receivers that are compatible with 5V TTL. In this case customer will need to use some sort of level shifter with our device.
