Part Number: DP83867IS
I am supporting a design using the DP83867IS; the board is undergoing compliance testing.
The "Peak Output Voltage" Test is coming back "FAIL". (Seems the amplitude is a little too low - see attached results)
The testing follows the TI Literature on Measurement Setup for Compliance Testing (SNLA239B)
As stated in the document:
PROG_GAIN(0x01D5) UNF_FUNC_MODE = 1
1) Do you have any thoughts on what's happening?
2) Is there a register to control the MDI Output Gain?
(Something like the IO_IMPEDANCE_CTRL for the RGMII)
3) Can the MDI Output Gain be modified by using PROG_GAIN(0x01D5)?
Darren
