Part Number: SN65DSI86
Hi team,
Customer has some questions, please see below questions, thanks.
1. Have you ever used this IC with the Qualcomm platform (i.e. did the panel light up smoothly)?
2. The customer may connect different panels at the back end (eDP side) of the bridge IC, so can the bridge IC be able to judge it and light it up smoothly?
Will the host side need to issue another config command to set the bridge IC to determine the panel parameters of the eDP side? Or can the bridge IC itself determine the relevant parameters of the eDP panel and light it up?
