Part Number: DP83TG720R-Q1
Hi!
Can you please confirm strap configuration for pins LED_0 and LED_1 while using the LED functionalities. For example, we would like to use MS=Slave and AUTO=Autonomous. By the following table those two options are both MODE 1.
By this table, MODE 1 means to leave the pin floating:
I if understood correctly, if we are using LEDs and we want MODE 1 (open, float) we would need to put additionally pull-down resistors as in the following image, right?
Matej
