Part Number: SN75DPHY440SS
Hello E2E Experts,
Good day.
Can we use this part between 30cm and 50cm? May this work if we put It on the Rx side (after the 30-50cm)? Or it would be mandatory to out it at the beginning of the TX signal? I ask this just for a question of cost.
On the other hand, the device has an I2C interface to set up the equalization. Is there any default setup? For the distances indicated, do you believe the chip could work with the default configuration?
Thank you in advance for your support.
Kind Regards,
Jonard Rico
Texas Instruments Customer Support
