Part Number: TS3DV520
Other Parts Discussed in Thread: TS3DV642
hi, i have a design with mipi-csi2 up to 1.5Gbps does the component TS3DV520 support mipi csi2 format with 1.5Gbps.
You can use TS3DV642 as a passive MUX for MIPI CSI-2.
David
The TS3DV642 port name is different as a way to illustrate the connection for the HDMI application, but each port has the same electrical spec. Please see below block diagram as a MIPI CSI-2 design reference.
David
