DS92LV3241: Can this IC is used to convert RGB to LVDS
Part Number: DS92LV3241
Other Parts Discussed in Thread: DS92LV3242, , SN65LVDS93B
Can DS92LV3241TVS/NOPB converts RGB to LVDS?
I am using (SN65LVDS93BDGG) this part in my design for converting RGB to LVDS output which will be given to Display.
But this part is out of stock. So, can I use  (DS92LV3241TVS/NOPB) this part for converting RGB to LVDS?
If not, please recommend a part with stock available
Thanks & Regards,
Pushkarani T L
  • HI Pushkarani,
    The DS92LV3241 is a serializer device that outputs Channel Link to the DS92LV3242 deserializer. To get an LVDS output, this serdes pair must be used.
    The SN65LVDS93B is a single serdes bridge device. However, it does not appear to be out of stock on TI.com. Where are you seeing it out of stock?
    Lysny
    SN65LVDS93B part is some 215 quantity is there in TI as of date. For safer side, I am searching alternate part for this.
    Anyways, if does not appear to be out of stock, will use this part.
    Thanks and Regards,
    Pushkarani T L
