Part Number: DS92LX2122
What is the register to desactivate the back channel to be able to make the eye diagram ?
Hi Jonathan,
There is a mode that provides a loop through output of the recovered forward channel after EQ equalization and prior to the CDR block. This signal will not have the backchannel, so you will be able to see an eye diagram. The loop through driver is accessed via the RES pins 38 and 39 (CMLOUTP and CMLOUTN, respectively). To enable the CMLOUT pins, program register 0x3F[4] = 0 (CMLOUT enabled).
Ben
