Other Parts Discussed in Thread: DP83869, , THS4551
PFA doc of Input & Output signal of DP83869
FYI, Comparing Input & Output of DP83869 with connecting CAT 5 cable and without connecting CAT 5 cable to RJ 45 connector.
SOP & SON Observation:
There is no difference in SOP & SON output signal in both the cases: With connecting CAT 5 cable & without connecting CAT 5 cable to RJ 45.
Note:
what does it mean if SOP SON outputs 1010101010….. signal ? (regardless if there was input from TD or not).
Kindly check & confirm its right or wrong ASAP.
Rajesh R
