SN65HVD3085E: How to get the previous version of DS (Revision L)
Guru 12165 points
Part Number: SN65HVD3085E
I have a question about SN65HVD3085EDGKR.
Is it possible to get the previous version of the DS (Revision L) to compare the changes in the datasheet, "6.5 Thermal Information"?
Astro
  • Hi Astro,
    Unfortunately TI does not make practice of publishing expired documentation. As of this posting, the current revision of the data sheet is SLLS562M.
    Regarding your question, I can help clarify that the thermal characteristics were updated in February 2022 as part of a qualification of a new fabrication site using qualified process technology in Richardson, TX.
    For the package you're mentioning, the new thermal values are reduced compared to the older obsolete characteristics.
    Danny
  • Hi Astro,
    SLLS562L.pdf
    It is attached - revision M is the correct version for this part still - but I have attached the last data sheet (rev L)
    Parker Dodson
