MAX3232 charge pump caps?
Other Parts Discussed in Thread: MAX3232
What is supposed to be the voltage/waveform seen at the charge caps on the MAX3232 ?
C1+ basically is at 3v and pulses up to 5.5v giving two 1uS pulses every 35uS
C1- basically is at zero and pulses up to 3v in the same way as above
C2+ is at zero and pulses up to 5.5v in the same pattern
C2- is at -5.5v (negative) and pulses "up" to -0.5v in the same pattern
  • Hello Yoda,
    The signals you reported are normal.
    The charge pump repeats these two steps as needed to keep V+ and V- at a regulated voltage.
    1) Vcc charges C1 while C2 inverted charges V- capacitor
    2) Vcc + C1 charges C2 & V+ capacitor
    Basically, C1 helps 'double' VCC and C2 inverts that 'doubled' voltage.
    Ron Michallick
