Part Number: DS90UH948-Q1
Hi, Expert,
There is an application case regarding [removed], like to consult you. Sorry choose part number as" DS90UH948-Q1" due to no [removed] selection.
In my application, [removed] receive audio sent over the serializer I2S pins. There are some questions during read datasheet of [removed]:
1. What's the mean of I2S_WC(word clock)? Is it right and left channel selection clock?
2. 4 channel data output(I2S_DA, I2S_DB, I2S_DC, I2S_DC) in [removed], May I know what's the different between 1 serial data output and 4 ch data output? Any hints during application about 4 ch data output?
3. Only 1 serial data input pin in the IC, which is used to receive I2S signal from [removed]. Is it OK we choose one of data output pin from [removed] to connect? Or any suggestion from you?
4. What's the mean of "I2S data word size"(Highlight in table)? does it same as pre sample bit?
Thanks in advance!
