Part Number: DP83TC811R-Q1
Hi Expert,
Could you please help me understand the accuracy of internal temperature sensor for DP83TC811R-Q1?
Thanks!
Ethan Wen
Hi Expert,
Thanks!
Ethan Wen
Hi Ethan,
The temperature sensor values read in register 0x0483 correspond to the following chart:
The exact numeric accuracy of the sensors has not been characterized unfortunately, so I cannot provide this information.
David
Hi David,
Below is customer's feedback, do you have any suggestions to them?
So in order to ensure we are in safe status (Datasheet define the MAX temp is 150℃), when we use it, we have to set this value no bigger than 101, because in step 110, above limit 165℃ has already exceeded 150℃.
But with this config, we are just wasting 15℃ margin (MAX 150℃ - 135℃)….. Do you have some ideas how we could improve ? Or nothing really could help….
Thanks!
Ethan Wen
Hi Ethan,
I understand the concern of the customer, but unfortunately the temperature sensor values cannot be changed.
David
