DP83867E: Ethernet Compliance and Loopback Testing Document SNLA239
Part Number: DP83867E
Other Parts Discussed in Thread: , USB-2-MDIO
Good day!
I want to ask how it is that the SNLA239 Application Note new revision on the TI website does not contain at all the loopback testing. I found on the internet (but not on the TI website) the previous revision and it contains both the Ethernet Compliance and Loopback Testing. I was just wondering why it was excluded in the new revision. The loopback testing I mean is the section where it is detailed the Near-End and Far-End (Reverse) loopback testing standard setup and configuration.
Also, for the 1000 BASE-T, may I ask if you can provide the test setup for Common Mode Noise Rejection? In the document, it is indicated "not included in this application note". At least a sample test setup for the DP83867E part, probably using the DP83867ERGZ-R-EVM and the USB-2-MDIO tool via MSP430 Launchpad if the launchpad is necessary for register configuration.
JM
