Part Number: TUSB321
We are currently working on a car USB C charger that will also have a data passthrough.
So, the charger will have a USB C port that will connect to a device that needs to be powered. This device will also transmit data so it's acting as a power sink but a data source.
Currently power is not managed and the device is connected directly to the Vbus (not USB C standard).
Charger will also have a USB A port that will also be powered. Data lines from USB A to USB C are connected together to allow a USB flash drive to be connected to USB C device while also powering them both.
We used TUSB321 for this since we already use it on other products and tried to set the charger as host to avoid any problems with users that will try to connect a UFP to DFP device that also delivers power.
We are trying to avoid any expensive PD ICs so if you have any other solutions that will be great.
Blaz
