TFP401 clock distribution
Other Parts Discussed in Thread: TFP401, TFP403
Please help my customer with the following (should I recommend the use of a buffer?)
Question about the TFP401. I will be using the TFP401 in a Dual DVI receiver mode. In the "Digital Visual Interface FAQ", question #10, is says to distribute the DVI clock to both receivers. Does TI have a recommended method to do this? Should a 1:2 fanout chip be used? Is there a part that TI recommends?
Thanks, Saeb
  • Hello Saeb,
    The TI's solution for a DVI dual link is to use two transmitters and two receivers.
    TFP410----------------TFP401/TFP403
    TFP410----------------TFP410/TFP403
    Regards.
  • I am re-stating the issue:
    My current design uses the TFP401 as dual DVI receivers.  According to the Digital Visual Interface FAQ from TI, question 10 states:
    10. How do I implement a dual link receiver using the TFP401?
    The TFP401 was not designed to function as a part of a dual link receiver. With dual link DVI, only 1 clock is transmitted with the 6 data channels. A single link receiver will deskew the 3 data channels it receives and output these with the ODCK signal to clock the output data into a register in the next device. To use 2 single link receivers for dual link, the DVI clock must be distributed to both receivers. The outputs of the 2 receivers must be recovered using their appropriate ODCK. Any skew between the receivers removed, and converted to a single clock domain.
    My question is how should the clock be distributed to both receivers?
     Is an external 1 to 2 buffer needed?
    Is there a TI recommended part for this?
    Thanks, Saeb
  • Saeb, you might consider using a dual-routed clock trace with a series resistor.
    RE
  • Hi Saeb,
    I work on a project similar to yours : a solution based on the use of 2 TFP401 in order to do a dual link receiver. Does this configuration work on your board ?
    Could you give me layout guidelines, clock distribution reference ?
    Laurent.
