we are using two 15.1inch display panels, one is from innolux and the other one is from highness,
we are using custom board with stm32f476 mcu with 16bit rgb to lvds interface, for rgb to lvds conversion we use sn65lvds93 chip. with this setup lcd from innolux works fine, but the lcd from highness starts to flicker.
at first i thought it is due to backlight, but the backlight voltage is stable, and also i think this problem is not due to board layout because the panel from innolux works fine with same setup.
so i am unable to find what is the actual reason,
