Part Number: DS125DF410
Other Parts Discussed in Thread: DS250DF410
We are trying to understand the definitions of the registers and functional block better in DS125DF410. The datasheet uses both of the terms VCO and CDR and they look like two independent functions on the block diagram level:
As far as we know, CDR should be a standalone function with its own set of circuitry including an internal VCO. So the VCO block shown on the block diagram should not be part of the CDR function. Is our understanding correct? If so, can you let us know how the two relate to each other? For example, when we change the VCO divider value (bit 6:4 of register 0x18) manually, will the CDR function for the input signals be affected?
Thanks.
