Part Number: TSER953
Hello TI Team,
I plan to use TSER953 in a camera application on a movable device. The coax cable will be at least 5m long.
There are a few documents explaining that the attenuation should be as low as possible, and information about the return loss / insertion loss of the pcb. I failed to find any information about the maximum possible insertion loss of the system.
As I want to use a very flexible coax cable the attenuation is already quiet high(and if I want to be cost efficient, it will be even higher). Therefore information about the maximum attenuation of the system would be really nice to have.
If this isn't possible, I would appreciate Information about the cables of test system you used to at least have an indication what is working.
Armin
