Part Number: DP83867ERGZ-R-EVM
Other Parts Discussed in Thread: USB-2-MDIO, MSP-EXP430F5529LP
I was just wondering. In your DP83867ERGZ EVM User's Guide https://www.ti.com/lit/ug/snlu190/snlu190.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1663924143744&ref_url=https%253A%252F%252Fnl.mouser.com%252F
you mentioned The DP83867ERGZ EVM power is supplied by a single 5V DC jack, are you talking to the LDO input highlighted in Figure 1?
If we use external power supply 3v3 or 1v8, is that something I can connect to the P2 Pin 3 - VDDIO_EXT? adding the R77 resistor and removing R74 resistor? Is this correct? Or are there any additional resistors to remove/add?
May I ask if DP83867 EVM evaluation board is still available or this becomes obsolete?
Thanks.
