Part Number: DS90UB960-Q1
One customer debugs DS90UB960 recently, and the questions are as following:
1. If used test pattern, it could decode MIPI signal normally, and could display normally@30fps.
2. When used DS90UB933, he found that the frame rate has decreased half of the original frame rate. The sensor worked the master mode.
During test MIPI protocol, it could meet the spec all, but when used sensor to light up, he couldn't find the Frame End packet.
While Test pattern mode, it could see the Frame End packet.
Below is the MIPI waveform, there is no Frame End packet.
Could you please help to analyze?
Best regards
Kailyn
