Part Number: DP83TC811R-Q1
Other Parts Discussed in Thread: DP83TC811
Hi team,
Here's an issue from the customer may need your help:
1) During the tc8 test, the signal generator was used to keep noise increasing to decrease the SQI value. After the noise was increased to a certain value, the PHY state did not change to link down. Why's this?
2) When master switches to slave, a problem has been observed with the loss value of the mode transition. What typically affects losses? Is it possible to change the value by modifying the software configuration?
3) The return loss values were also found to be problematic when doing the return test, what was the impact on the return loss values? Is it possible to change the value by modifying the software configuration?
4) When switching to testmode 4, the transmitter distortion = 20 mV. Is there any other way to configure the values besides setting the mode?
Could you help check this case? Thanks.
Cherry
