Part Number: TUSB8020B
I found some old and closed topics about tool for EEPROM programming for TUSB8020B USB hub. It would be great if someone can send me a copy of it.
Artur Laskowski
Artur Laskowski
Hi, Artur
Can you please accept my friend request so that I can send you the software through E2E private message?
David
Hi Artur
I sent you the programming tool, would you please check and see if you received it?
David
To summarize efforts: I received programmer software, and after some repairs, it started working. But there is a problem: I have 64k EEPROM, which requires a 2-byte memory address to write, and the programmer (or hub itself) gives only a 1-byte address. Is it possible to change this behaviour, or must I change the memory for another one?
Hi Artur
The TUSB8020B requires 1-byte addressing. Below is a list of recommended EEPROM.
David
