Part Number: TCA9511A
Hi Team,
If EN is not connected to VCC, but to another power supply, and pull up the output signal (SDA_OUT/SCL_OUT) to the power supply where the EN pin is located, is there any risk in this use? Thanks.
Regards, Charlie
Hi Team,
Regards, Charlie
Charlie,
There shouldn't be any issues in the situation you've provided. As long as you provide a high enough bias on EN (as clemens pointed out) then the device should work. If the EN voltage is higher than the Vcc voltage, you may see some slight leakage current but it shouldn't affect the operation/application.
-Bobby
Hi Bobby,
Thanks for your update. What if the voltage of EN is equal to the voltage of VCC? How does slight leakage current arise? Thanks.
Regards, Charlie.
