What is the MAX value of tPWRUP?
The datasheet only defines TYP value.
The MAX value is required to determine the waiting time until the start of communication.
A maximum value was never characterized for this timing. Normally the INH pin controls your voltage regulator that powers your MCU. So once the voltage regulator powers on your MCU will turn on and you can start communicating with the device.
You are more than welcome to test the variance in the start times with the INH pin but TI can not guarantee any values outside of the datasheet.
Chris
