Part Number: LMH0397
Hi, we are trying to develop a SDI repeater with LMH0397. But we have some question about LMH0397 layout:
# 1
The datasheet suggest us to place the power supply decoupling capacitors on the bottom layer. But won't the vias lead into more inductance? Is it OK to put the capacitors on the top layer?
# 2
We are trying to use LMH0397 as a SDI repeater, so we are gonna set LMH397 in EQ mode and use SDI_OUT+- and SDI_IO+-, but at EQ mode, the OUT+- is default enabled, and we are not gonna use it. Should we just leave it float on the PCB ?
# 3
If OUT0+- can be float, then can we use Layer2 as the reference of SDI_IO SDI_OUT 75Ω impedance ?
