Hi Sir,
We use DP83867IRPAPT, when the Host uses tftp to transmit data, it will cause the DP83867IRPAPT's light to go off. Try to modify the LED Blink Rate, the problem still exists.
The lights are controlled by LED pins.
In the video, the first 23 seconds are the behavior of the light signal when it is inserted, and the 23~43 seconds are the behavior of using tfpt to transmit data.
How to solve the problem that the light signal is constantly off during transmission?
BR,
Taylor
