Part Number: LMH1226
Hello
I'd like to know under which circumstances the OUT0/1 differential outputs of LMH1226 can be DC connected to its destination, without bulky series capacitors.
I don't see any statement in the datasheet concerning the common mode dc output voltage, whether it is simply generated by sinking current into some internal termination resistor, to which power pin such an internal termination resistor is connected, whether it uses some sort of internal voltage regulator for the internal termination resistors etc.
In other words I simply can't infer the output configuration from the datasheet. Can you provide such information, or even better, augment the datasheet with those details ?
