Part Number: TCAN1462-Q1
Hi expert,
Will TCAN1462-Q1 need the common mode choke coil for TI recommendation usecase?
In TCAN1042 case, datasheet discribed as below,
EMC performance: supports SAE J2962-2 and IEC 62228-3 (up to 500 kbps) without common mode choke
If all TI's CAN tranciver don't need it, could you please let me know technical reason for reducing common mode choke?
Also do you have any limitation in reciever side for using SIC CAN? I think it is improved ringing of signal, so the reciver don't have any concern.
Is it correct?
Mukuno
