Part Number: SN65LVP20
What is the current requirement for the part if the enable is tied high (output disabled)?
I went through the SN65LVP20 characterization data and it does not appear we tested this condition. And unfortunately we no longer have the setup to test this particular condition in the lab.
David
From the schematic of the part's design, do you expect the power dissipation to be significantly different from the active state?
The output will be in high impedance state with /EN pin being H, so I would expect the power to be lower than the active state.
David
