DP83867E: DP83867E vs. DP83867I
Part Number: DP83867E
Hello Team,
the datasheet for the two parts is the same, so beside the temperature difference I'm assuming that all the programming and pin functionalities is the same.
In particular, can you confirm that if there is no need for high temp, it would be possible to switch from one to the other using the same PCB?
I have only notices some timing difference between the two parts (session 7).
SunSet
