Part Number: DP83848Q-Q1
Hi Expert:
I'm currently testing DP83848Q-Q1 power up timing. May I know what's "Dual function pins become Enable as outputs" means which pin output ? thank you
Hi Expert:
Hi Roy,
This refers to any I/O pins that are configured to act as outputs once the device is powered. The specific pins this applies to will depend on the configuration.
Hope this helps,
Evan
