Part Number: TCAN1462-Q1
Hello team,
In TCAN1462-Q1 datasheet its mentioned there is internal pull-up on STB and TXD pins but i could not find the value of those pull up resistors. I need this data in order to calculate external pull-up resistors. So could you please tell the value of resistor and which value of resistor you would suggest to connect externally.
Thank you,
Kavana H
