Part Number: DS90UB954-Q1
Other Parts Discussed in Thread: DS90UB953-Q1,
Hi team,
One of our customer's issues, I'm forwarding it below, could you please provide some troubleshooting suggestions
The DS90UB954-Q1 and DS90UB953-Q1 pairing work.
The sensor currently uses raw8, 4lane, mipi rate is 729Mbps, 1280 * 720.The 954 uses a 23MHZ crystal and outputs to the 953 23MHZ. Can the 953 support this data?
At present mipi always reports the following questions:
Virtual Channel 0 Frame Sync Error
CRC Error
Data Id Error
May I know what may be causing the problem, and at present the host side can only capture data once by using the v4l2 application to capture the image, and then execute will report time out. What could be the problem? This problem can also occur if run pattern directly on 953
Amy Luo
