Part Number: DP83TD510E
Other Parts Discussed in Thread: DP83822I, DP83848J, DP83822IF
Hi Ti Team,
We have designed a 10BASE-Te to 10Base-T1L Full-Duplex Media Converter using the DP83822I PHY and DP83TD510E SPE PHY and are currently exploring a re-design/spin to a readily available Ethernet PHY (due to DP83822I shortages)
We understand not all Ethernet PHY's support RMII Repeater Mode: RMII Slave-Slave (with clock sourced via 50Mhz Osc) operation and timings on the RMII interface are critical.
Will need to support capacitor coupling (replacing RJ45 magnetics) so forced 10Mb full-duplex (Auto-Neg Disabled) operation is also required.
We can see the DP83848J has a healthy inventory would this PHY be a viable solution to replace the DP83822I in our design?
If we were to use the DP83822IF will it be okay to drop into our current design without any major changes (we are not using Fibre) but stock is available in low volume?
Kind regards,
Daniel
