Part Number: DP83822I
Other Parts Discussed in Thread: TMDSCNCD28388D
Please tell me about the RMII for dsp83822i.
The environment is the control card "TMDSCNCD28388D".
PHY is initially set to BootStrap for MII.(RMII_EN = 0, XI_50 = 0)
After startup, necessary GPIO and MDIO 0x0017 are changed to RMII (Master Mode) setting.
RMII Clock Select = 0
RMII Recovered Clock Async FIFO Bypass = 1
RMII Mode =1
I thought that the 50Mhz clock is automatically output from RX_D3 when I change from MII to RMII, but when I check with an oscilloscope, it does not seem to be output.
Is there some setting I need to do?
