Part Number: DP83822I
DP83822I for 100M Base-T Design, follow datdasheet design, RBIAS=4.87kohm.
1. Interface template signal: only 80/100 times pass
2. Overshoot fail: >5% limit
Which component or register should be changed to solve these issues?
Hi Liang,
Can you please share the schematic of your design?
Please share the eye mask also for reference.
Gokul.
ECG-RBIAS=4.87K_Rout=3.3ohm_RPU=62ohm_Fail2.PDFDP83822I_PHY_SCH.pdf
Hi Gokul,
Attached the files for reference
Hi Liang,
Can you please let me know the following?
Gokul.
1. R321,R322 are 0ohm
2. 2.2ohm and 5.1ohm for lightning protection
3. ineffective
4. C42,C44 = 1uF+0.1uF, is ineffective
5. ESD diodes must not be removed,for ESD and lightning protection。
Is there register for matching, that we can adjust it through software codes ?
Hi Liang,
Let me have a review with our team and get back to you.
Gokul.
Hi Liang,
Happy New Year!! Sorry for the delay in my response.
We couldn't find any registers to correct this as we don't understand the reasons for failure. Once we understand the rootcause, we can check again if we can do something with registers.
For experiments only, can you please remove series resistances of 2.2ohm, 5.1ohm and remove the ESD diodes and check the mask? We want to look at the performance without these components to understand why there are failures.
Gokul.
