Part Number: DS90UB934-Q1
Hi Team,
Curious on an item from the 934 datasheet regarding the OEN and OSS pins. This table which shows that when certain conditions are met that Pclk, Data, and Lock output will be pulled low by the deserializer.
The “Inputs” section of the datasheet is unclear, it refers to serial inputs being static or active:
1.Can you clarify what is meant by serial input (ex: Is is the forward channel or is it I2C communication)?
2. What criteria determines static vs active? Is it a timeout?
2bIf it's timeout related, what is the setting of the timeout?
3.Also could you clarify purpose of using serial inputs as criterion for the output?
