Part Number: LMH0324
Hello E2E,
Please let me know about "Input-Output Mux Selection" on datasheet.
"These settings can be overridden via register control by applying the appropriate override bit values."
I understood this sentence as "The hardware setting of the IN OUT SEL pin can be overridden by the register setting".
Is my idea correctly?
If it's correct, I think that this device can receive following operation.
1st: The IN OUT SEL pin to be float, OUT1 set to Disable.
2nd: The OUT1 change from Enable to Disable with register settings.
Are these operations possible?
If the above operation is possible, could you tell me the address and setting value of the register that should be changed?
ACGUY
