Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869
We plan to use DP83869 as RGMII to 1000base-T physical interface.
I've checked into datasheet that PULSE HX5008FNL transformer is recommended. This transformer have center tap (phy side) separated from each other :
Is there any issue to use such MOLEX 937698628 RJ45 with integrated magnetic, but with center tap connected from each other : ?
I understood that common center taps connected is more used for physical interface using current mode driver.
Thanks for your feedback.
