P82B715: Can I connect the NC pins to ground
Part Number: P82B715
The datasheet says the pins are not connected internally, however sometimes NC means No Connect, so do not use at all.  Just to make the ground plane better around the SDA/SCL lines coming in, I would like to ground both NC pins.  Is that OK?
