Part Number: TDP1204
Hi, TDP1204 support team
As for 4-Level Control Pin Setting, Table 8-1 is specified to use 1kohm as a pull-down resistor for Level 0 and a pull-up resistor for Level 0. Can these 1kohm resistor change to 0ohm? In other word, Can 4-Level Control pin connect directly to GND or VCC instead of using 1kohm?
At least, as far as I see the schematic in the users guide, 4-Level pin can connect directly to GND without 1kohm resistor.
Tamio
