TS3DV642: TS3DV642 Unused Pins
Part Number: TS3DV642
For unused pins like CEC, CEC_A, CEC_B, D2+/-, D3+/-, should I leave these floating or terminated with a resistor to GND?  Is there an app note to describe this?
    We recommend that all the unused I/O pins like the CEC are terminated with 50 ohms to ground to prevent reflections in the signal path.  If you application isn't very sensitive or low speed you may leave the I/O pins floating if reflections will not be an issue.
    David
