Part Number: SN65DP159
Hi Experts,
We are using the SN65DP159RSBT in our designs, we want to know the Tx/output supports,
RX is mentioned upto 16.5db ,But not finding the tx values.
As per the datasheet, it is mentioned " keep total trace length for signal pairs to a minimum" , but we are not sure the minimum values, As per our design , it comes around 7inch trace length due to our design environment. is it Ok
Could you please tell the loss requirement between SN65DP159RSBT to HDMI connector.
Karthik
