Part Number: DP83TC811EVM
Other Parts Discussed in Thread: DP83TC811
My goal is to use this evaluation board to determine PHY signal strength via ethernet
1. connect an ESP32
2. connect DP83TC811EVM to another board via ethernet
3. connect an ESP32, read some values from DP83TC811EVM via serial to determine PHY signal strength
I reviewed your User's Guide and am confused how to get started. Here are some questions I have:
1. How can it connect to an ESP32?
2. The box does not contain a power source, how can I power this up?
3. Once it is powered up, does it need additional setup?
4. I see this on the main page - DP83TC811EVM-CDC-Driver Software - Does this need to be loaded onto the board? If so, how?
5. The User guide mentioned firmware, not sure where to get / how to load it?
6. Any beginner friendly guides how to get started?
Thank you.
