Part Number: TUSB522P
Other Parts Discussed in Thread: TUSB1002A
Can TUSB522P and TUSB1002A co-layout?
TUSB1002A |
TUSB522P |
Pin # |
Pin Name |
Recommendation |
Pin # |
Pin Name |
Recommendation |
Power Pins |
1,13 |
VCC |
One 4.7 μF and one 0.1 μF capacitor to GND |
1,13 |
VCC |
one 4.7μF and two 0.1μF capacitors to GND. |
6, 10, 18, 21, PAD |
GND |
GND |
GND |
GND |
Configuration Pins |
5 |
EN |
100nF to ground or NC |
5 |
EN_RXD |
4.7k to VCC |
7 |
MODE |
NC |
7 |
NC |
NC |
2 |
CH1_EQ1 |
1k pullup/pulldown |
2 |
EQ1 |
47k pullup/pulldown |
3 |
CH1_EQ2 |
3 |
DE2 |
16 |
CH2_EQ1 |
16 |
DE1 |
17 |
CH2_EQ2 |
17 |
EQ2 |
4 |
CFG1 |
4 |
OS2 |
15 |
CFG2 |
15 |
OS1 |
14 |
DCBOOST# |
NC if this function is not used |
14 |
RSV |
NC |
USB Data Lines |
9 |
RX1P |
When connected to AP, 0.1 or 0.22 μF AC coupling capacitors
Otherwise (connector), the recommended values are 330nF, 390nF, or 470nF +/-10%.
Polarity swap is supported by USB3 spec |
9 |
RX1P |
8 |
RX1N |
8 |
RX1N |
19 |
RX2P |
19 |
RX2P |
20 |
RX2N |
20 |
RX2N |
22 |
TX1P |
0.1 μF or 0.22uF AC coupling capacitors
22 |
TX1P |
23 |
TX1N |
23 |
TX1N |
12 |
TX2P |
12 |
TX2P |
11 |
TX2N |
11 |
TX2N |
Misc. Pins |
24 |
RSVD1 |
NC |
24 |
NC |
NC |
