Other Parts Discussed in Thread: LMH1218
When running the IC in open loop mode, this IC can pass 11.88Gbps SDI video, as well as 3G-SDI with pathological stress-test pattern very well. However, in closed loop, the signal will nearly drop out.The datasheet has a recommended COMP cap value of 0.01uF to control the bandwidth of the APC loop. It seems the APC loop reacts too quickly when the large change in data density happens creating the pathological test pattern.
How large of a COMP cap value can be used? What does the APC circuit look like?
