MAX3221: About the time to output when switching from Automatic power down to normal operation.
Guru 11515 points
Part Number: MAX3221
Hi team,
I'd like to know about the automatic power down.
Could you tell me about the time to output when switching from Automatic power down to normal operation?
I think the automatic power down is switched to normal mode by the input signal.
I want to know if I need a dummy signal to wake it up.
Sincerely.
Kengo.
  • Kengo,
    After device remains in invalid signal state for more than 30us, device will enter auto-power down mode.
    Please let me know if this answers your question.
    Tyler
  • Tyler,
    Thank you for your reply.
    No,
     I'd like to know is how long it takes for the output to come back on after the auto-power down mode is restored.
    Sincerely.
    Kengo.
  • Kengo,
    MAX3221 exits a power-down state when any valid signal is present on the receiver. While we don't specify this explicitly in the datasheet most likely due to the slow data rates of RS-232, I would think the timing would be similar to the output enable/disable timing spec typically ~200ns. The only exact way to know for sure would be to scope the input and output to see the time differential after coming out of a power-down state.
    Tyler
