Part Number: TUSB1310A
I received a question from a customer.
1. I am experiencing 8 b/10 b Decode Errors, are the following posts relevant?
2. Do I need special circuitry to avoid 8 b/10 b Decode Errors?
Nishie
Nishie
It may related to the same issue. Is this new design?
Brian
Hi Brian-san,
Thank you for your replry.
I sent you a private message.
I would appreciate it if you could check it.
Also, it is not a new design, customer has been using it since 2014.
Nishie
Hi Brian-san,
I will ask the customer if they have passed the RX JTOL test.
I have also sent a private message with material about the customer's situation.
I am sorry to trouble you, but I would appreciate it if you could check it.
Nishie
Nishie:
it looks material lot related. Pls contact Ly Set and CC Chia HS.
Brian
Hi Brian-san,
Please let me know the contact information for Ly Set and CC Chia HS.
Nishie
Hi Brian-san,
A board mounted no problem devices passed the Rx JTOL test.
Nishie
ok, maybe transmitter issue, but since it's lot related, still suggest to do ATE first.
Pls accept my friendship request.
Brian
