Hello Team,
My customer is asking me to explain FRC and Hi FRC.
Here is what I understand from datasheet.
1) There is 4 kind of FRC.
-FRC1 is conventional FRC. it is dithering from 8bit to 6bit. this is front of white balance IP so this is independent of white balance.
-FRC2 is to dither 8bit data from LUT to 6bit conversion in case of 6bit input. FRC2 operates with white balance IP.
-Hi FRC function extend to 9bit from 8bit. and this has 4kind of algorithm to choose in case of certain incoming data like black/white, full or all off R/G/B pixel.
but I don't know difference between Hi FRC1 and Hi FRC2.
Could you pls kindly explain this in more detailed?? and other my understanding is correct??
Thank you.
